CVT fluid change
Pieter van der Putt
Hello, Pieter from the Netherlands here. I've just bought a Toyota Avensis 2011 with a CVT transmission with 90 miles on the clock. The fluid for the CVT transmission has never been changed. What is the wise step? Change the fluid? Or just leave it as it is?
Thanks and cheers.
 just leave it as it is.
change spark plugs + new tiers instead.
drive safely.
Check the service manual or ask the servicing department at a Toyota dealership.
I do not know what the recommendations are for Toyota CVTs. But is is worth finding out, because the fluid in Nissan CVTs should be replaced every 6 years or 50,000 miles. Quite a few that have not break at around 70,000 miles.
