Hi All,
Toying with the idea of upgrading the Speakers and adding a sub to my 2024 GR Sport PHEV.
Not the worse audio sound, but I’ve had much better and would have gone for the upgrade option if available.
Would anyone know if I am likely to find the sub cable already installed behind the left hand side boot trim ?
I know from previous experience that some manufacturers fit a ‘one loom fits all’.
Any help appreciated.
Thanks.
12 minutes ago, Station said:
Hi All,
Toying with the idea of upgrading the speakers and adding a sub to my 2024 GR Sport PHEV.
Thanks.
If its like the Prius, then the JBL loom (intended for the JBL amp under the passenger seat is different wiring to the standard setup. In that case no…
Ah, OK.
Would have been handy.
Thanks for the reply 👍
1 minute ago, Station said:
Ah, OK.
It is fairly easy to run a new loom to that location
I’ve done installs on a few cars over the years so it will OK
Fallen lucky a couple of times with wiring already in place for various things - not so this time though.
Cheers.
Cheers.
Good Luck
