I have set my dashboard to show me driving assist in the middle and energy monitor on the right. Or another page driving assist in the middle and tyre pressure on the right. Every time I shut off the machine and start it again, it will show me something else. All messed up. Middle one changes to settings, and right one to song that is playing. Why it is like that. I am logged in. And it is not the choice of three different pages of  displays - it messes all of them.
kaotage
There does seem to be a few bugs in the system - particularly with showing tyre pressures.
I’ve had my display set to show them and then next time I started, tyre pressures weren’t there.
switching between one and two dial displays also changes what’s shown - it doesn’t seem able to keep the setting you had.
my current display with one dial has been stable for some time now though.
Yes, my problem is it does not keep my settings. Will talk to Toyota about it.
Is it due to 24 my cars all safety systems defaulting on key off, maybe?
My dashboard display now shows the tyre pressure screen when loading my settings which is great, but the odd thing is, sometimes my profile doesn't load first time and defaults to guest mode but if I shift out of Park and go into Reverse then go back into Park my profile will load with my saved settings for the dashboard display. It's a real quirky system for sure. This doesn't happen all the time but I seem to have stumbled across a fix when my profile doesn't want to load first time.
Try going into profile settings, press edit, make the instrument settings you want, go back to profile and save it before switching off.
I don't think so.   I have a MY24 version and it doesn't behave like OP's car.   I have my meter display set up as I want it to be;   it stays  as set.
Yes, a lot of the TSS changes back to default settings every time the car is switched off, but it doesn't change the meter screen.
Yes. You were right. I went to the center display screen. Checked the profile and i was logged in as quest somehow. Logged in myself again. User already there. And it is now keeping my settings. Simple thing. But resolved now. Thank you
I too wanted to have the tyre pressures set as default screen, I know in my 23 plate corolla the tyre pressure screen doesn't show after the engine is switched off and left for a few minutes, it defaults back to the hybrid Battery screen, I know there is a posting somewhere on here (I did a quick search but couldn't find it), so you're not alone
how do i get to tyre pressure display. i've searched through owners handbook without seeing any mention
Using the Settings menu, scroll to Vehicle Settings, press and hold OK.  You can then scroll to TPWS setting.   This is for the 12.3 inch display (which I assume that you have).
thanks for info but not working in my car. no option to press and hold ok
The tyre pressure warning system info is not exactly easy to find in the Manual but it is there:   look under 'maintenance and care', 'diy maintenance, 'tires' (sic).   I'm referring to the on-line Owner Manual here, not the User Guide.
Alternatively, and IMHO better, there is a tutorial for the meter display in current models in the 'How to Guides' section of this forum by "GasGas" (in the Corolla Club Guides section).
If you can't get to the TPWS info after following above then I guess that there might be a software issue (which would probably surprise no-one) and you may need to visit a dealer.   Good luck!
thanks again
