Interior assemble guide on toyota-tech.eu
rotormania
Hello, I am trying to find out on toyota-tech.eu how is it called the section containing the assembly of various parts of the Auris interior, like the driver seatbelts, and the plastic covers on the left of the pedals area.
I need such schemas in order to be able to open such panels to put the cables of the Dashcam. I already have that on the Corolla E12, but I want to do the same on this car without risking to break the plastic rivets
I doubt you will find an official document describing the procedure.
This information is available from TIS but you pay by the hour, for an online session and can take screenshots. Hope you find what you are looking for.
I have taken the central gear console out without breaking anything and without instructions. Good luck.
its not hard, plastic trim tools are a must, avoid the cheap ones as these tend to bend and snap
edit. Have a look on eBay or google for the parts you want to remove, it gives you a good idea of where the clips are located
