Toyota Auris 2017 headlight position
MrPorter
Hello, I own 2017 Toyota Auris (hatchback) and I'm trying to adjust the headlights, I found the way to adjust the position up and down but I can not find the way to move it left or right can someone please help me and of course if you can take a picture to show where it's located.
in the picture you can see how badly the right side headlight is
Thank you
Thank you
Have you changed the bulbs recently?
perhaps putting one in upside down?
Hello, yes I changed them to LED but that was long time, I thought it’s an issue with the bulb so I swapped left side bulb with the right one but the bulbs are fine it’s just the position which is not correct, I don’t know how to adjust Left and right position.
Also the bulbs can only go in 1 position. Can’t put them in different position.
thanks
I dont think you can adjust left/right on the 2017 facelift model. Atleast i couldnt find it on mines.
Cheap bulb filament/light source can be off centre, causing horizontal divergence.
So basically it was the bulb…. Yeah it was faulty …
thank you everyone for your help
