Service advice !!
Filip.08
Hi everyone ,  I am I bit confused about what to do I currently have an  Auris 1.2  2016 bought from main dealer 3 years ago with nearly 58000 miles on it  , no problems so far just consumables  , next service is a full service which is 370  it's a bit expensive to be honest  ..I want to go just for warranty but I am not sure  if it's worth or not 😣😣 , thanks 🙏
as you mentioned above just for the warranty it is worth it.
You can ask the dealer what exactly is included in this full service, at this mileage you need to replace spark plugs , air filter, cabin filter, brake fluid , you can check and do Wiper Blades , and ac regas, but those things will be at extra cost. 👍
some of them I think they replaced it last time , thanks for your help, I've just went through my old posts and I've realised that I asked same question for the same problem two years ago 😂
Bit ambiguous - did it have 58,000 when you bought it, or is it on 58,000 now?
If when you bought it, what mileage does it have now?
My mistake) 58000 that's the current mileage.
£370 is the standard price for the Full service.
I'd check on the invoices for the last two services as to what has been replaced - ie what was done at the last Full service @ 6 years old. Spark plugs (due at 6 years/60,000 miles, whichever occurs first) may have been done at the 6 year service.
Is the a/c working OK (eg. is it cold enough)? If OK, a re-gas may not be needed.
Filters and brake fluid change should be included in the Full service.
Presumably there is also the MOT.
As above, check with the dealer as to what they've included.
At the end of the day, you can take it to an independent, but it may not be much cheaper, and won't include the Relax service generated extended warranty. Depends really what your budget is and how much you can afford.
