1 hour ago, FROSTYBALLS said:
If it is a unit from an Aygo, then no code is needed. The following covers replacing the head unit - the later 3 button unit has Apple Carplay/Android Auto:
Thanks so to get this right to have no code needed it has to co e from a similar Aygo not a 108 or C1 and as my current has xnav it also needs that built in as well ? Or i go for the 3 button one and add car play.
The 108/C1 use the same head unit.
As the 3 button head unit can use Carplay/Auto, and from the topic I linked to, the older sat nav (X-Nav) module as fitted to yours won't be compatible with the later head unit.
the xNav is just an xTouch with the add-on module - be aware the xNav module does not work with the later 3 button triple play unit
86140-0H020 £65-130 is about right used
eg. https://www.ebay.co.uk/itm/256599412369
Again thanks , so to keep the xnav i have to use a two button head unit or if i get a 3 button I basically use carplay maps etc
Yes.
correct
