Avensis coolant low
Willss
Just checked my avensis engine coolant and found the level has dropped a fair bit. First guess would obviously be a pipe connection. Seems to be some pink on a couple of nuts on the left side of the engine. Is this likely to be spray from a leak on a pipe or could it be indicative on something more untoward? Oil level/colour looks fine.
From what I can see pipework isn't covered by the Relax warranty so may get it investigated locally!
can be water pump but 2017 i dont think so ... keep on checking its not missing a lot. check when the cat cold morning or so ....
Will try to get it looked at early next week. Engine cool when photo taken it's a 2017 with 75k miles. If I keep checking levels and it doesn't drop further should I be OK with driving short distances over weekend?
If it's sprayed it's more likely from water pump. It could be one time event but also sign of water pump slowly failing. Not uncommon with Toyota according to my googling.
13 hours ago, avensis_2018 said:
there is no one time event with toyota avensis believe me.
We are going on a 1800 mile holiday trip soon so will be sorting it in next 10 days. Not going to risk anything!
