Finally got round to replacing the pathetic standard horn.
Toyota premium horn kit part number 08522-B1010 fits & works perfectly.
It's a right pain to get to the original horn ( unless you want to remove the front bumper which I didn't ) but you can just see / access it with the slam panel plastic cover removed.
One replacement horn fitted in the original location & the second horn bolted to the slam panel all hidden under the plastic slam panel cover.
Great upgrade...2 questions.
Did you order it via eBay from one of the many sellers in Japan.
Did it come with the split harness connector so it's just a plug in the original connection and then the 2 new horns.
Did you order it via ebay from one of the many sellers in Japan.
Yes ordered via eBay & came from Japan.
Yes it comes with the plug & play split harness plus some extra fixing hardware ( which I didn't use )
