Is carplay/android auto possible in my system any help
Is carplay/android auto possible in my system any help would be appreciated. Theres no option for it
What year is your Rav4?
In short No, you have a mm13 touch2 it does not support AA or ACP, add on modules are expensive
How do i check ?
1 minute ago, maazkhan98 said:
How do i check ?
From your V5C vehicle registration document.
However Flash22 has already replied and stated your head unit isn't compatible with AA/Carplay.
Should this be in the Prius forum? It says Prius in his profile and on his air vents.
MM16-19 no AA / Carplay however there are a number of aftermarket units you can replace the original head unit with that support AA / Carplay. Normally retailing for around £400..
The other product you see advertised are aftermarket 'Android boxes' which connect into the existing media unit, being mounted behind it, which then depending on the particular unit, adds Android auto and/or Android app support through the existing system.
I got a box that i use for my skoda Mk3. Thought there might be something similiar for this. Doesnt seem like it
Draw your own conclusions but all “boxes” require aa/carplay on original head unit or take your chances on Chineee knockoffs
good luck
Had a pioneer top of the range fitted into my 2015 Rav 4 it fantastic the DAB quality is way better than the original unit. Cost me nearly £700 including fitting and all the extra add ons like camera wires etc well worth it
