Hello!
I used to post here many years ago as Arthurpewty...I can't log into that account...so here I am with this account!
I have a question about my 2nd car.
Yesterday someone collided with my 2020 Rolla Excel and trashed the n/s front bumper...then drove off and didn't tell me
That is what it is...🤬🤬🤬
The problem is that the parking sensors keeps bleeping randomly and I have to temporarily switch them off.
So is there a way to switch off the sensors until the bumper is repaired?
Thanks in advance 😊👍IMG-20240630-WA0005-1.thumb.jpg.4f67115a7bf65ccaeb2dab6b7cbbff79.jpg
  • Sad 1
O/s front bumper...😊👍
Can you accept the sensor, put it back in the hole and tape it secure as a temporary repair? Can you turn them off in the cluster settings?
36 minutes ago, Craigsvinyls said:
Hello!
I have a post-facelift (24MY) version;   I can turn the sensors, and the associated braking function, on/off in the Settings menu.   What I am not sure about is whether they will default back to 'on' when the car is restarted.
I assume that your dash display is probably different but that similar menu options are available?
Hey thanks for that. It has seemed to work as a permanent setting unless it refreshes as default after a set amount of time.
I tried it and switched everything off for a couple of minutes and it's all good.
Thanks for the info... legend 😊👍
You're welcome.   Shame that someone damaged your car and didn't leave details or report it.   Sadly, all too common these days.
