Fitted a magnetic charge pad
jthspace
I saw this on Amazon
Charge Pad
The mount above the display is a magmount I use if the phone is in its case or for my PMR microphone if on a run with friends for car-to-car comms.
Lead has been tucked in the gap between plastics, but I could dismantle dash and hide the lead better; but this looks OK for now.
£20
  • Like 3
3 hours ago, TonyHSD said:
Very good.
I do not like wireless charging as this add extra heat to the battery.
Heat in battery world means one thing  - fast degradation.
My new YC will have wireless charging and I'm going to monitor how warm the phone gets when charging, especially as it's kept in a padded case (to protect it from the inevitable drop). At home it gets charged overnight on a wireless stand, but a low powered one which seems to be ok.
Like Colin mine is in a drop case. For charging in the car, usually when being used for navigation, so on continuously, it's out of the case in a holder for best cooling.
(I also take it out if fast charging, though I usually use the Android smart charge overnight which doesn't blast it.)
My limited experience with wireless charging was that it's pretty slow, so heat wasn't an issue. It just seemed inefficient and another thing cluttering up the place.
However that was a few years ago, so maybe it's got more potent now.
If you click on the link, you will see that max charging current on the pad is 7.5W for iPhone 15/15Plus/ 15 Pro/15 Pro Max, iPhone 14/14Plus/ 14 Pro/14 Pro Max, iPhone 13/13 Mini/13 Pro/13 Pro Max, iPhone 12/12 Mini/12 Pro/12 Pro Max and 5w for ipods etc.
If you want 15w charge then you have to connect the phone direct to the charger.
