St205 Sparkys
skippa
I want to change my plugs.
Do I need to drain the coolant from the header tank?
If so, is there a drain plug fitted anywhere?
TIA,
B)
I've never heard of having to drain the coolant to fit spark plugs??
Is this a celica thing?
Spark plugs are simply un-screwed and replaced :thumbsup:
The header tank is on top of the engine in a GT4. It obviously needs to be removed in order to gain access to the plugs. I just want to know if and how to drain the coolant from it!!
:help:
The GT4's have the Charge cooler on top of the engine .. I've have thought this would be easy to slide out without having to remove the coolant ..
