Fuel gauge error
Bell97
My fuel gage is showing 3 bars and i have just filled up. But the screen so screen is still saying low fuel. Had anyone else had this before and knows how to fix it? Thank you
How much did you fill up by? If you don't put enough fuel in it doesn't reset the readings.
If you only fill by around 15 litres or less, that can cause issues ....
  • Like 3
The wifes Aygo (2020) fuel gauge is so incorrect and you never know how much fuel is in it.It will go up a bar then down a bar and back up again.Bring back the real gauges.
All gages can go up or down on the reading depenting on the angles the car/tank are under
IE. Going down hill or up hill.
