ok anybody able to confirm if the hard brake line on a ST205 is the same as a ST202
part number (47321) or is it different due the the 4 wheel drive, floor plan lay out
looking at replaceing the line, with any advise
Are you thinking of taking one off a 202 salvage car? You'll have problems trying to find new Toyota parts.
Rear Brake, No.1
ST202 - 47321-20380
ST205 - 47321-20390
http://japan-parts.eu/
basically yes, obvioulsly it would have to be in good enough condition
which is going to be difficult due to the age of these cars
or use it for a template to get one made up, or other possible solution
is repair the section of line, which would probably be better, as the car is
currently not on the road to take to a work shope to copy the one on there
If it's just badly rusted along a short section, best way would be to splice in a piece of copper-nickel (Kunifer) brake pipe.
from the EPC it says the line is the same part number for 205 and 202
but as said think that reparing the quite small section is the way to go
been looking on what i takes to make/flare lines, doesnt seem so hard would need a flaring tool also any advise with regards to the actual fittings needed, M10 for the nut going into the flexi?
the section from the rear right needs doing so the nut attatched to the flexi and some minor bending and the actual joiner needed
would be very gratefull for any advise or recommendations
2 minutes ago, Raybrig said:
...same part number for 205 and 202
Part numbers are different, see my updated first post.
correct the basic EPC diagram only shows the the actual line number
Clicking/tapping the number reveals a pop-up with the full part number.
very frustrating when looking for a select part to have corresponding number, which in reality are not compatible
thanks for the confirmation, unfortunatly im working of EPC diagrams and not the actual EPC catalouge, as i dont have access to one
which is obviously not ideal
I'm using the online EPC.
202   205
43 minutes ago, Raybrig said:
...would need a flaring tool...
I bought this to repair my brake lines. Got a perfect flare the first time I used it - (did a test piece first).
DSCF1584.thumb.JPG.e4ecf53321708538aaff2d37cd6de6a6.JPG DSCF1585.thumb.JPG.b5c24dc07b951e4d13e7bcdd2a9cd56a.JPG
DSCF1586.thumb.JPG.ac73171931845b646b0344c4fc037e52.JPG DSCF1587.thumb.JPG.195c70384425cddf946d02063c852d19.JPG
Thanks for the info, was the tool im looking on getting
would be a great help if you could confirm the fittings required, i believe the flare is a (double flare) also the nut connecting to the flexi is a 10M
also a suitable joiner, id be very interested to know how you did the process, as in bleeding the brakes and whats involved, or would it be better to start a new post specific to replaceing a section of brake line   Thanks
Here are the fittings that I bought.
10mm x 1mm thread pitch.                       Inverted flare nuts.
DSCF1592.thumb.JPG.d817dd5d050baf2552790667f181373c.JPG     DSCF1589.thumb.JPG.819b888776631799ef9dadaf3ceca3ad.JPG
DSCF1594.thumb.JPG.8717b494e35a55d4dd8b6361dd1d152e.JPG     DSCF1600.thumb.JPG.3d6a672568fcfbe512baec62202afead.JPG
One side screwed in finger tight.          Mini tube cutter.
https://www.ebay.co.uk/itm/355857946698
Workshop manuals: http://gt4.mwp.id.au/
The brake bleeding process should be covered in the 205 chassis & body manual.
This is a good time to upgrade the rubber "flexi" brake lines to Goodridge, Hel, braided hoses.
Thanks for the detailed information
