Hello,
My urban cruiser 2010 1.4 D4D recently started to emit black/grayish smoke from exhaust. When driving normally there is no smoke but going above 2.5K Rpm and fully accelerating then it starts to emit and keeps emiting untill i let go.
I have figured out that driving aggressively for some minutes will eventually come to a point where no smoke will come out whatever i do.
On the other hand driving below 1.7K rpm constantly for some minutes no smoke will come out but the first moment i accelerate hard it will emit insane amounts of black/grayish smoke to the point where it makes like a big cloud.
I also see no significant change in fuel consumption or any power loss.
The car has its particulate filter removed some time ago.
I did all the cleaning, and egr check but everything seems fine.
What can i do?
Regards
Hah, reminds me of my dad's old TDCI Focus - He'd usually only drive it on very short journeys, so short he'd sometimes get as low as 130 miles out of a tank :eek:
One time I borrowed it and when I got to the on-ramp onto the M25 and floored it, a massive plume of soot blasted out the exhaust - Must have scared the bejeezus out of the guy behind me :laugh:
It does sound like there is soot building up in yours for some reason, and then getting blasted out when you accelerate harder. Need to narrow it down - Could be bad fuel, variable turbo vanes stuck, partly clogged injectors, hardened soot obstructions in the exhaust, faulty/blocked EGR...
I'd try running a few tanks of Shell V-Power diesel or equivalent (Or some fuel system cleaner like Redex or BG244) through it first to see if that makes any difference...
