Ok, sorry everyone if I put this in the wrong section, anyway, I own a 2012 Toyota highlander. The power liftgate wouldn't close and struggled to open so I purchased a motor for it, Instead of replacing the entire assembly. after the replacement it makes quite a bit of noise when opening and closing the kind of noise that sounds like it needs to be lubricated the only issue is I'm not sure what kind of grease I should get for the gears. If anyone has an idea on what would work best for this please give me an answer. Thanks in advance.
Topic moved to the Highlander forum.
