Hi all, I need your help...which wire (or number on the plug) is for +12v and ground in a 2017 Yaris Hybrid? All 4 the controller, not only main LHD
I have the wiring diagram but not for +/-12v and I'm thinking to do a work, so I know I have to disasseble the controller and check the 12v but I don't have the car til august
@flash22 🍻
the main power is fed directly to the window motors, the window switch is just a control side circuit
4 electric windows - Pin 1 - white/black, Pin 6 - Gray
4 20a door fuses and a 30a Power windows fuse
I remember that I blew up a 30a fuse LOL
so, I can take 12v power source from pin 6 (+) and pin 1 (-) from all 4 switches...thanks, as always!
yes but put an appropriate fuse inline
ok, so I have to buy 5 inline fuses (one for the main, the other 4 for the doors)
I wanna install this kit, the old one got damaged thanks to interior cleaning
New kit
far greater quality than the other one I had installed a year ago
no, just the 12v feed to the module
but there are 5 modules with +/- pairs on each one
I have already installed the window switches with the light on all the doors, this ambient LED kit has 4 slave modules and a master module, I could put a 5A inline fuse (or 2.5A) on each module...the main 12v source for the master is from the start button (like the old kit that worked perfectly), the 12v source for the 4 slave modules that are inside the door connected with pin 6 and pin 1
the new kit: https://it.aliexpress.com/item/1005005657359652.html?gatewayAdapt=glo2ita
@flash22 hi Bob, I have disconnected all the third part things and now I have the start/stop illumination button that does not turn off (the OEM one, I never changed it)
even if I lock the car after 15-20mins, the illumination on the button is still on
disconnect the Battery for 15 to 20 mins
8 minutes ago, flash22 said:
disconnect the battery for 15 to 20 mins
It has been disconnected for all night long from the big white wire
Do I have to disconnect from the Battery?
see the other notification on the other thread 🙏🏼
yes from the Battery
3 hours ago, flash22 said:
yes from the battery
1h fully disconnected, nothing has changed
  • Sad 1
