Non start
katdov
Hi we have a 2017 proace 1.5hdi that has no crank non start all ignition lights on plenty of voltage in Battery remote fob works any ideas before I burn it thanks
There is nothing on key nothing at all seems like it's blown fuse but checked all them just when key turned no click mo sound at all
First thing is attempt to turn the engine over by hand - the 1.5 HDI has a known fault where the timing chain between the two camshafts can break.
Remember this is a Peugeot in disguise.
I'm going to guess electrics - French engines aren't actually too bad normally, but their electrics are a constant source of problems.
Have you got an ODB scanner or something to check for codes?
