Car wraps
2toyos
I currently have a black land cruiser that is scratched up from daily use and a particular nasty mark from a scummy person, im looking to tidy it up, as it looks embarrassing, I'm thinking of wrapping it, what are your opinions, experience on this matter
Wrapping is normally less expensive than a respray, but prices vary based on the difficulty  of the wrap and the vehicle size. A good quality wrap can last between 5-7 years or more, but it can be affected by weather conditions and how well you look after it.The wrap can be removed later if you decide to sell the vehicle.
If the scratches are deep they should be properly repaired before applying a wrap. This involves sanding, filling, and priming the damaged areas to ensure a smooth surface. If this isn't done properly the imperfections might still show through the wrap.High quality wraps can cover minor imperfections but may not fully conceal deep scratches if they’re not repaired first.
I'm thinking about this, I've resprayed a car before and it was nothing but hard work, I thought this would be the better option as I want to change colour the easy way, I can repair the biggest, I didn't know if it was worthwhile
