Stock suspension vs Bc Coilovers
Arnasst205
Hello
I need to change my suspension on st205 because one shock absorber is leaking and one in the back broke and not sure if i should go with stock or bc coilovers.
Currently my car has bc coilovers but i don't know what spring rate is on it, but it drove like **** on British road, felt every bump on the road.
Also my front fenders started to crack, i suspect because of very hard suspension hope changing suspension will sort it out.
I am daily driving my st205 and only on road.
I know bc coilovers are better at handling corners, but i don't know which is more comfortable to drive and which sits higher from ground, stock or bc coilovers.
Hope you guys can answer me these two questions
Thanks in advance
My choice would be stock KYB (Kayaba) shocks fitted with a set of lowering springs.
