Hi
Is there a list of what needs to be done at each service interval?
Eg 30km / 45km / 60km, etc, etc
From looking around, Tesla's need very little and Hyundai can need a lot depending on which service (expensive).
Isn't it covered in your Service Booklet? If not, it will be detailed on the service schedule that you get back from the dealer after each service.
All electric cars are made very similarly and they don’t really need much to be done, the service mostly comprises of checks and visual inspections. Cabin filter replacement 20k miles, but you will be better off if you do that more often depending on what car is and what type of filter has, Wiper Blades, and top up screen wash are the most common thing that gets done. After the 60-80k miles mark an ev transaxle fluid change is recommended although it might not be required by the manufacturer as most of them call these filled for life.
Coolant change perhaps after 100-150k miles.
14 hours ago, TonyHSD said:
All electric cars are made very similarly and they don’t really need much to be done, the service mostly comprises of checks and visual inspections. Cabin filter replacement 20k miles, but you will be better off if you do that more often depending on what car is and what type of filter has, wiper blades, and top up screen wash are the most common thing that gets done. After the 60-80k miles mark an ev transaxle fluid change is recommended although it might not be required by the manufacturer as most of them call these filled for life.
I have checked again, don't have a service booklet detailing the needs at each service. My last service, they replaced cabin filters, checked levels, brake fluid, checked Battery, etc.
So if the first service has already been done, don't you have a service checklist from then, which usually details what is covered as part of the services (Intermediate and Full)?
The attached is a Warranty and Maintenance Guide from the US. The Maintenance Log lists all the items that need attention at each service interval. It's a US document so the service intervals won't be correct, but the list of items needing attention will be equally applicable over here.
T-MMS-23_bZ4X.pdf
Thanks for this document. Hopefully generally applicable over here. Not to many items to be replaced, more checking.
