Brand new Z4. I set the charge time for 9pm but I can not turn off the charge now function as it will not light up to accept the command?
I was told at the dealership that if you enter a charging schedule on the car you also need to set a stop time.
Guess that's why the button isn't lighting up?
you will have to delete the schedule and start again
I deleted mines today as i had the Toyota charger fitted and use the charger to set up charging times
if you have schedule set up on your car you have to switch it off if you go to a public charger when your out and about or the car will think its on a schedule and only charge at the time you selected
