My new Yaris Cross (2024) is showing the little yellow tyre symbol, probably because I checked the pressures and topped up two of them. I need to reset the TPMS I think, but all the YT videos show a little button below the dash which I don't have.  This leads me to ask how to get to the vehicle settings menu on this model.  I know about the buttons on the steering wheel but nothing leads me to that particular option.  The chocolate teapot (otherwise known as the user guide) doesn't help.
Topping up should not result in the low pressure symbol coming on, only decreasing the pressure may result in that.
It should be the buttons on the steering wheel and menu in the dash, think you have to hold the button for a few seconds to get into the pressure settings and reset, then drive a bit. Don't remember all the steps.
I had to reduce the tyre pressures on mine, you need to go into the settings menu / vehicle from memory and reset the warnings there.
You can download the full owners manual from https://www.toyota.co.uk/customer/manuals
Printed copies should be available to order, at your cost, from your dealer. Approx £25-30.
Assuming it's the same as the standard Yaris then it's
Settings> Vehicle Settings > TPWS Setting > Tyre Pressure Setting > Setting by current pressure
