Hi my brake warning light comes on and flashes intermittently on my 2000 1.4gs Corolla,checked brake fluid it's betweem min and max any ideas please?
Brake pads check and parking brake cables and lever if the lever returns to default position. These can set the red warning brake light too. 👍
If the handbrake lever and the pads both check out fine, check the pad sensor wiring for chafing or some kind of short to earth other than via the pad itself.
