Speed Limiter and Cruise Control
Barry33
Good Afternoon
This is my 1st post so hopefully am in right place. I have recently taken delivery of my Yaris Cross design 24 plate and have to say am really impressed. So many things to get used to however one question I have is I have mastered the speed limiter function no problem however I was just wondering if is possible to switch from speed limiter to cruise control and back whilst in motion.I thought I had worked this out but switched from speed limiter to cruise control and then unable to switch back to speed limiter. Have checked maual but it does not appear to cover this scenario or maybe I am reading instructions incorrectly. Any help appreciated
I believe you have to cancel whatever is active, then you can press mode (that's what is in my OHs Yaris) then mode to switch then activate again.
Topic moved to the Yaris Cross forum.
Very easy yo quickly cancel then apply cruise or speed limiter. You do need to set them after though which maybe what you are trying to avoid?
