difference between ABS module 44510-30270 and 44510-30290?
i need to replace the abss module and it looks like 33270 may work in place of 33290 - is that correct?  what is the functional difference?
Hi, did you find out if these two parts are equivalent? I need to change the ABS module on my Camry Hybrid 2007 and it is a 44510-30270.
44050-30660 is the part number for the entire module
