Does any one of you techies know were the the OBD port is located in the new 2024 CHR PHEV Design thanks guys. Also has the Key fob have a long press function on opening the vehicle so that all the windows will open, last but not least can you setup a lock the car function when walking away from it with the key fob I your pocket.
Dealer needs to set up the long press windows opening/closing function 👍
OBD port is under the dash at the driver's side.  Both the global windows and the walk away locking (by pressing the second button on the boot lid) need done via OBD.
