CH-R C-LUB 2024 - Illumination and 360o camera
Hello all,
I have a CH-R C-LUB 2024 and I want to know if it's possible to add Toyota's illumination lights and 360o camera as C-HIC has. I have a contact with my reseller that I bought it and after check, they told me that it's not possible on this model.
Do you know something different?
Thank you in Advance,
Konstantinos
First, you have a C-HR rather than a CH-R ...
Your dealer is essentially correct - these are NOT dealer fit options that the dealer could reasonably supply and fit for you. Indeed, they are not factory fit options that you could have chosen to have fitted to the C-LUB grade in the factory.
That said, you could theoretically purchase all the relevant parts (you'd need to identify part numbers) and modify your car yourself or have some third party modify it for you. This would of course invalidate the manufacturer's warranty (as well as being prohibitively expensive).
The most practical and cost-effective course of action would be to sell your C-LUB and purchase the grade that has the equipment that you require. Note that the C-HIC does NOT have PVM.
Alternatively, enjoy the car that you have ... 😉
Thank you very much for your reply. It seems you're correct.
