Hi All
On my Yaris Hybrid 2021 Something fell on the set of EV/ECO mode/Drive mode buttons and popped them out.What is the best way of removing the panel to refit them or can anyone point me in the direction of appropriate documentation.
At that age of the car, it should be under warranty still. Go back to Toyota and get them to fix it.
You will need to pop the centre console trim off, most of it is clips iirc there is 1 screw hidden under the gloss trim on the left, you can get away with just loosening the trim above the glove box
that being said you may be able to get to the back of the switches by popping the gear selector trim
