Avensis Dcat 2010
Rosie71
Hi everyone
just looking for help regarding my Toyota Avensis Dcat , seem to have a diesel smell which has been diagnosed as normal for my model !
my Nephew noticed that underneath the wheel arch where filler is , it’s wet with diesel and has soaked into something like a lining and has swollen and pushed the bumper out
so I’m not sure what to believe now , has anyone come across this before? And do I have a leak ? Or is it a case of overfill ?
many thanks
Rosie 71
Maybe the tank cap seal is broken or worn?
I once had an Avensis T27 diesel stw and it  occasionally leaked out from the cap if the tank was full. I discovered that the cap had to be turned a little more than the click indicates, then it was tight...
Is the side of the car wet outside or just wheel arc inside?
If just inside, there may be a leak a top of the filling pipe?
Is there any pressure when opening the cap?
It’s inside wheel arch , thanks for the information it’s something to consider
A smaller pipe (overflow pipe?) coming from the upper end of the filling pipe. Would it be broken?Täyttöputki, polttoainetankki NTY
oh not sure will get it checked thank you
