T25 disassembly the air conditioning evaporator
zimon
patient avensis t25 1.8 petrol. problem with air conditioning.
at first leak from the area of the air conditioning radiator.
radiator and gaskets replaced with a new one. tightness in the engine compartment preserved.
We did not check inside. After filling the air conditioning after two days the system was empty. next check of the system engine compartment without leaks of refrigerant but from the vents and behind the glove compartment with the fans turned off the sensor was closed.
Diagnosis evaporator.
Can it be removed without disassembling the entire cockpit? Does anyone have instructions on how to get to it without breaking anything (screws, clips, latches)
