2015 GT86?
Phil White
Back in 2018 i bought a used 2015 GT86 with only 7000 miles on the clock from a Toyota dealer with one previous owner. I have known for a while that there is a NUMPAD in the glove box that are fitted to all UK GT86 cars. Apparently its for programming the alarm and needs a 4 digit PIN code to access it and make any adjustments. I was NOT given any manuals etc by the dealer and therefore i have no PIN code. Toyota were unable to help and therefore i have no clue how to do a Reset if that's even possible.
Vehicle security specialists cannot help me either.
Does anyone on here know a way for me to get the PIN code or a reset code?
Sounds aftermarket; Either get it removed or try and contact the previous owner n the V5.
the manual states that the key for the car has the answer and to take to a dealer, there should also be a little silver dog tag with the pin number on it, also the original owner will have had a silver sticker he/she might have stuck it somewhere, if you are on facebook the uk owners might have the answer if you ask on there
Huh, apparently it is factory fitted - I didn't know that!
Mine had it. Part of the alarm and I think they're fitted when they land in the UK.
