Can anyone confirm the specifications for a Yaris Excel hybrid spacesaver wheel for a 2024 HSD ?
I believe the size is T125/70D17 98M
But is the 5 stud pattern 100mm (centre of 1st stud to outside diagonal stud) ?
Are both 17" Yaris and Yaris Cross spacesavers interchangeable?
Just remember that a max of 10% difference less in size is possible
10% of 17" is 1.7" = 16" or 17" diameter spacesaver
10% of 18" is 1.8" = 17" or 18" diameter spacesaver
10% of 16" is 1.6" = 15" or 16" diameter spaces aver
You may find a 16" diameter spacesaver is cheaper and easier to source than a 17". You may never need it and if you do have to use it, it should only be used to get to a replacement store at max 50mph.
Thanks for the detail. Yes 16" are easier to find (and cheaper)
Just concerned regarding the stud pattern dimensions (5×100 and center hole size ?) to confirm if an alternative model with the same spec/size will fit.
I have a space saver for my 2024 Excel which was supplied by my dealer
I will measure it tomorrow and post the details here
Many thanks. That would be so useful.
Hi
you can use this site to located different sizes and if they fit in between
https://www.wheel-size.com
Have now measured my space saver
Hub is 50 cm diameter and the radius of the fixing holes is from the centre line is 50 cm
Thats the closest I can get with the kit I have
What I can’t measure is the chamfer angle on the fixing holes
Looking at the web link you were given the hub diameter could well be 54.1 mm
Thanks for all the replies.
It looks like the space saver I need is ;
T125 70D17 (or 16,18) 98M 54.1mm hub and 5x100mm pattern.
Hopefully if someone else searches they will see this thread.
