Hello! New here. I was wondering how you can tell if my Mk1 was the 1.6 16V version. And if the engine was 80KW or 85... etc.
I have the original manual but not sure where I can find these information.
AW11 unless its a JDM car will be a 4AGEL, 118 bhp 16 valve
Edit. that has had an engine swap/rebuild so who knows what has been done to it or the power output it's either a blue or red top but the cam cover has been repainted
It's usually shown on the top of the camshaft cover.
OP's image what I downloaded and converted shows a silver cam cover with all red lettering
Red samco type silicon hoses all around
Blue top block has 3 ribs, red top has 7 ribs iirc
1 hour ago, flash22 said:
OP's image that I downloaded...
Maybe you could post that image?
That's a mk1a so possibly a 3-rib small port.
EDIT: Just saw the title of the post. 1985 would almost certainly be a blue top (3-rib/big port). Of course, it could have been swapped at some point.  Anecdotally, bum dynos have the older engines as more peppy than the later ones.
