Posted (edited)
Hi
ive fitted a new radio to my 2011 aygo
it turns on and works but doesn’t save presets
Fromm reading online I think I’ve connected the ACC not the Battery positive
can anyone confirm if the aygo cable colours are the same as other cars?
yellow- B+
red -ignition
blue-ant
Black ground
the wiring diagram for the new radio is in the photo
the yellow wire had a seperate plug
On the original radio… is that the constant Battery line?
I am confused
Edited by Inho
Spelling
Hi Joe and welcome to the board. :thumbsup:
When I changed the radio in my 2012 Aygo, I got an ISO adaptor with bullet connectors on the red and yellow wires, as in your case, the radio switched on but the presets wouldn't save.
I just swopped the red and yellow wires over at the bullet connectors and it's worked perfectly for many years....Job done!
I suggest that you do the same as I can't remember which colour is constant and which is acc but a simple swop works.
I hope that helps, all the best! :biggrin:
I had to connect Red to Yellow and Yellow to Red on both MK1 & MK2 Aygo.
Thanks to both!
really appreciate it
