Can anyone tell me how to get at
the reverse bulb?
Tried to pop the lens off but seems abit tight not sure if
it comes off from the front..
Car is 2020 CHR Reverse light is at the bottom of bumper.
under the car should be a plastic cover that will need to be removed and gain access to the the light cluster. This should be fitted with bolts to the bumper.
Nice 1 tony thank you.
2020 c-hr
unplug the wiring from the lamp and check for 12V when in reverse
if it has been dealer serviced it should be covered under the 5 year warranty, if it's not the bulb/led (not covered)
EDIT
2020 lower centre light in the bumper is the fog light, reverse light is on the tailgate either led or bulb
unless you have the combination fog/reverse light then it will have an LED for the reverse 81679-f4010 and a bulb for the fog
