Toyota Celica 89
XsebioToyota
hi, I i have a Toyota Celica 89.I am having serious probelms with the power on the car On park it seems to have all the power yet when i take it for a drive i have to put the peddle all the way down to go at least get 15 mph on,its same on reverse.. i changed the timing belt,i dont know if that has anything to do with it .. The car does not shake or anything just lost power please let know know anything if you know... i would be greatfull
check you cam timing it sounds like you may be a tooth out thus causing loss of power
Does it rev high without the power? I had that prob recently and it was the clutch slipping.
