Egt sensor location
Dec73
Hi I have a code p0546 circuit high bank 1 sensor 1 on my avensis 2016 2.0 diesel its a faulty sensor but need help in locating it as I haven't a clue
sorry, don't quite understand what you're asking
I think he means the Exhaust Gas Temp sensor, I'm afraid I can't help with the location, possibly around the exhaust manifold would be my guess but that's just a guess, give it a while OP and I'm pretty sure someone will show you where it is.
ETA: You try putting your VIN in here ..https://japan-parts.eu/toyota/ and see if that shows you a location ?
Edited by Shared
Link added.
Sorry I am looking for egt sensor bank1 sensor 1
Thank you I will try that
Hi Declan,To locate the EGT sensor. Open the bonnet and find the exhaust manifold, which is usually located at the top of the engine and connected to the engine block.Look for a sensor attached to the exhaust manifold or the exhaust pipe just after the manifold. This sensor will have an electrical connector attached and often appears as a small metal cylinder or probe. If you need to replace it, unplug the wiring harness before removing the sensor.Make sure the engine is cold.
Thanks I see 2 sensors that look like egt sensors 1 on left and 1 on the right I just don't know if bank 1 sensor 1 is the left or right
