Yesterday my rear control arm (trailing arm) literally shattered as I was driving. Thankfully I was only going 5 mph. Unfortunately everything was so rusted together I had to cut it all off. Now I'm looking for parts and I cannot find the rear brake backing plate for the life of me because Toyota discontinued it. I am seriously stumped and have nowhere else to turn. Is there some kind of generic part or something?
I don't see anyone else with this problem so there must be a solution I'm not seeing.
can you pm me a vin or frame number
rear arms can be a pain to find
That backing plate is just a heatshield for the brakes to the brakelines so not essential; I'm always surprised they didn't make more as they rust to smeg over time!
You can probably make one out of sheet metal or get a fabricator to make one, esp. if you still have the old one as a template.
They can make it out of stainless instead too which should last longer!
Yes, I'm unable to find the trailing arm as well. Vin is Jt3hp10v5w7096888
OEM code can be found
REAR SPRING & SHOCK ABSORBER | Toyota RAV4 SXA11L-AWMGKA SXA1# | Parts Catalogs | PartSouq
Details 48703 or 48707, but is it with or without ABS?
I can see 4871242904 and 4871242904 in Estonia 930€ 😲
ARM,RR SUSPENSION OEM 4871242904 - Originaal varuosa TOYOTA-LEXUS - alvadi.ee
