Engins Cuts off
PROIT
Hi Guys
I am new to the forum.
Need some help to determine what causes engine cut off. Its Toyota Auris 1.6D  2017 reg. This has happened few times now. Car engine stops when its stopped on traffic lights with showing engine light umber and red EPS(electric power stering light). When I restart its got no power for a while and then power comes back on. It has happened few times. Two different mechanics has checked it and cannot find anything wrong with it. Its DPF has been cleaned. I have noticed some time it throws white smoke while driving. Any suggestion or idea what could be wrong with it will be much appreciated. Its been services recently.
Hello, With the few things you describe, the temperature sensor may need to be changed. This is also a symptom of white smoke on the exhaust. How many kilometers the car has is another factor that doesn't actually solve the problem but gives you an idea how to proceed further
you need to get it code read.
the white smoke could easily be DPF regen.
Two mechanics used their computers to read the code. They both said there is no fault code. It’s done 114K miles. When it restarts and I press accelerate it feels like it has no power for a few seconds then it picks up power. Is it worth taking it to Toyota garage for diagnostics? Thanks
1 hour ago, PROIT said:
Δύο μηχανικοί χρησιμοποίησαν τους υπολογιστές τους για να διαβάσουν τον κώδικα. Και οι δύο είπαν ότι δεν υπάρχει κωδικός σφάλματος. Έχει κάνει 114 χιλιάδες μίλια. Όταν κάνει επανεκκίνηση και πατάω το accelerate νιώθω ότι δεν έχει ρεύμα για μερικά δευτερόλεπτα και μετά παίρνει ρεύμα. Αξίζει να το πάω στο γκαράζ της Toyota για διαγνωστικά; Ευχαριστώ
They are the so-called hidden lesions that go undiagnosed
Or perhaps check a bmw forum and a bmw specialist.
Your car I believe has a bmw engine and Toyota technicians aren’t very good with those. The beemers has their own things and people who drive and work on, know them best.
took it to Toyota Garag and they cant find any thing what is causes this. The want to tear down engine to find the fault which is £900 labout. Might be nore to fix the fault if they manage to find it. Is it worth spending this much money to try an dfind a fault? They are supposed to be expert as its their vehicle should know what could be causing it?
Imo not a good idea to spend  any money to try to find a fault if they don’t know about it. Toyota technicians do not know anything about these cars. Your car should be covered by extended warranty. If not for any reason, find a bmw independent specialist on the net, Facebook, YouTube. Speak to them and book an appointment with them if they are happy to look at your car.
These guys works on these engines every day and they know them well.
xrhstosgr
where is location of temperature sensor? one of the mecahnics has found the sensor might needs replacing but he is says he does not where the sensors are located? can some one help please?
Thans
21 hours ago, PROIT said:
xrhstosgr
Thans
But how he knows that the sensor needs replacement?
is he a bmw specialist?
Which sensor exactly?
check here
https://www.sytnerstevenagebmwparts.co.uk/showAssembly.aspx?ukey_product=131985614&ukey_assembly=11494978
he used computer and told me its temperature sensor no 3 needs replacing as its wasn't showing right temperature. But he did not know where the sensor was located? It was bit surprised for me to say the least that he did not know its location?
He is not BMW specialist.
He was trying to diagnose why DPF is blocked?
Not familiar with this engine, but it may be exhaust gas temp sensor.
The 1.6 diesel is the 1WW based on the N47
What temperature sensor there are 2 coolant sensors and 2/3 in the exhaust
does the car have stop/start?
The NTC (EGTS) are not listed by toyota, oem is Denso tho
car has start/stop.
I asked Mechanic again he is saying his computer was showing sensor 3 wasn't showing any temperature(some thing like in minus). He tried removing the sensors he knew the locations but this sensor no 3 was still there showing as present. He spoke to Toyota garage but they did not helped him. I spoke to Toyota myself the send me a picture with sensor no 3. I showed that to mechanic he is saying he has same diagrame but that is not the one which shows as faulty and he has already checked it. I am confused myself why a mechanic and Toyota does not know which one is sensor no 3? it does not make sense to me?
Please see picture - the green highligted one is sensor 3 - accoring to Toyota.
any ideas much appreciated.
2 egts
Top sensor
89425-YV010
bottom sensor (highlighted in green)
89429-WA010
pics for reference https://www.ebay.co.uk/p/2197127335
I am not able to access the information at this time for diagnostics
There are no codes related to this sensor? has the back pressure sensor been checked? has the EGR and intake been cleaned - the swirl flaps are a big issue on these BMW engines
I am going to ask Mechanic to check these parts. I was assuming he shoul have checked these as part of his dianostics?
Been to see BMW specilist he is saying it will need DPF and Turbo replacing which is going to cost thousands of pounds(2500 - 4000)? is it worth getting it done?
Is the car still under warranty? If so, not sure if the "Relax" warranty covers these items but worth the ask.
Car is under warranty max £2K...too expensive
so it's not under the Toyota Relax warranty but 3rd party?
Hi.
i think that BMW mechanic want  only  your money.
My car had similar problem  T d4d .   Fuel filter was partially blocked first time MAF sensor dirty second time
it is 3rd party warranty - got rid of it now. Lost alot of money though.
