I was looking at PCS settings and found that the distance setting was midway 2, so I change it to high 3. When I restarted the engine the system defaulted to setting 2
Not to be confused with the distant setting in Active Cruise Control.
Has anyone else had this problem, I would rather the PCS worked sooner than later
Did you save the revised setting to the driver profile?
How do I save it ?
1 hour ago, Roker said:
How do I save it ?
Choose the "edit" option from the driver profile (activated by your key or phone), make the setting changes you want and then go back to the profile and hit "save".
  • 4 weeks later...
I do not have keys or set it by phone
I set it by going in to the setting on the steering wheel go to PCS and hold the centre OK button to change the sensitivity , I cannot find any save setting
So you don't have a driver profile? Do you drive it as "guest"?
Are you refering to Toyota? There is no driver profile
I think @RabButler is referring to the profile on the media unit, but if per your profile you have the 2020 car, that's not on there. It's a feature of the newer connected media systems on 2023 onwards.
From memory, on my 2021 corolla, once I've changed any of the settings you mentioned they stay there.
