  • You have a 2004 Toyota Runx 4wd losing power when hot.
  • RPM gets stuck around 2500 and doesn't increase with acceleration.
  • No signal on the dashboard.
  • Despite changing fuel pump, filter, plugs, and injectors, issue persists.
Throttle body and map/maf seniors cleaning is needed if haven’t done that yet. Another possibility is fuel filter.
These have been done
