I own a 2003 Corolla 1400, VVT-i. Recently I've had the airbag warning light flashing. I ran a diagnostic scan & got these results: B0133 - Current - Short in Pretensioner Squib (RH) circuit (to+B);  B0133 - Historic - Short in Pretensioner Squib (RH) circuit (to+B) and B1100 - Historic - Airbag Sensor assy.
I managed to reset the fault, however, I got the warning light back again after three weeks. This time around, I disconnected the connector from the pretensioner and ran another scan, with these results: B0131 - Current - Open in Pretensioner Squib (RH) circuit;  B0133 - Current - Short in Pretensioner Squib (RH) circuit (to+B);  B0133 - Historic -Short in Pretensioner Squib (RH) circuit (to+B) & B1100 - Historic - Airbag Sensor Assy.
The warning light is now steady 'on' and cannot be reset. As can be seen from the results, the B1100 (historic) fault has been replaced by the B0131 fault, obviously triggered by the disconnected connector. After reconnecting the connector to the pretensioner and running another scan, I got the B0133 and the B1100 codes again as current faults, and the following as historic faults - B0131, B0133 & B1100.
I was suspecting that I either have a faulty airbag module or a faulty pretensioner, but the fact that a short circuit is still being detected with the connector removed from the pretensioner, makes me think that there may be a problem in the wiring harness (two yellow wires) leading to the the airbag module.
Can anyone shed some light on this, maybe some other member has experienced this same problem before?
If you search for "Car pretensioner and AirBag problems"  you will find lots of posts and ytubes about locating the problem including using a Resistor Plug to mimic the suspect device.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
