😊 hi everyone hope everyone is good and happy 😊 I’ve got a Toyota estima 2021,trying to google my fuse box but can’t seem to find it,mine is on the drivers side inside,my radio has blown a fuse,I’ve replaced fuse before,but when u take one out for like lites it would set the horn off or something else ????has anyone got any ideas please 🙏
Hi Arlene, as your Estima is 2021 if you purchased it from a Toyota dealer it should be under warranty. As you have already found one fuse box have a look in the engine bay near the Battery or on the driver’s side under the bonnet.
You say you have replaced the fuse before so providing you put the right size fuse in it should not blow unless you have an electrical fault. Is the radio original or have you replaced it with an aftermarket radio.?
If it is under warranty and you haven't changed the radio then take it back to to the dealer.👍
