The Sera is having a spa day tomorrow
Paul_S
You'll probably find it cheaper on eBay and you won't need the inverted flare nuts unless you want to join/splice the copper pipe to a piece of the original pipe.
eBay - Brake Pipe
Did you not bother with a tool to bend the pipe?  Maybe just use a socket set or alike to pick the correct radius?
I used a socket on a short extension bar and clamped the bar into a vice so the socket sat on top of the vice.
