Hi everyone I am trying to hardware my next base dash cam with a piggyback to  15 A outlet, it doesn't work I don't understand why? Someone has any experience with hardware a dash cam?
A photo of your set up will help people to look into it.
I assume you have earthed it correctly?I used one of the door bolts to do mine
D
I had a similar problem with my Dashcam wired via a piggyback fuse.  After a conversation with Nextbase, I realised where I had gone wrong - the fuses were in the wrong slots. i.e. I had put one fuse in one slot and the other fuse in the other slot - as you do. Apparently, the piggyback fuse holder will only allow power through both fuses if they are inserted correctly in the correct fuse way. Yes, I know it sounds daft, but once I swapped them round, both the Dashcam and accessory socket worked correctly. This was using a Nextbase piggyback fuse holder. And as has been pointed out, the earth must be a good connection.
I've took it of from auris and it worked as it is right now , I does my mind I can't figure out what is it )
Hi , so at this point I am confused I've tried to test the fuse box with a multimeter trying to find the right one and it looks like they are all dead when the car is off, is that possible or I am doing something wrong?
I think it's the earthing point, try another part that have no plastic.
Ok i will give it a try ))
I've tried, at this point I think something is wrong with the dash cam (((
Okay, power it up indoors and see
