Disconnected the MAF cable (and IAT) and drove for a while (10-15km) without them - I did not notice a noticeable difference in the engine behavior, just as I did not receive any "check engine" errors
Disconnected Battery (ECU reset) and again driven 10-15 km with MAF+IAT cable taken off.
No "check engine" lights. Zero errors via OBD2.  How it is possible?
Let's continue my blog))
I haven't changed the ECU yet (waiting for soldering iron for eeprom), but once again I did a ECU "reset" by removing the Battery for a while.
For the first 15-20 minutes, the car drives normally and there are no hesitations, but then, when the brains "learned", hesitations are appear again.
intermittent MAF/IAT, aftermarket MAFs can be wildly out of tolerance, remove the plug and make sure the pins haven't spread apart give them a good clean with a contact cleaner spray
As I mentioned above, I think I have the factory MAF,  and data from it seems to be adequate (from 1 to 30 g/s). + normally responds according to throttle opening.
The IAT shows a little more than it actually is, but I also found a lot of information that on many cars the IAT can show +5...+10C from the actual temperature, due to heat from the engine.
The only thing I'm interested in - is when I remove the socket on a warm running engine, does the engine have to stop immediately?
Because my engine makes a short "stutter" like seems to be about to stall, but then it quickly levels off and continues to run. Do you think this is normal?
and quite low RPM on idle also can be cause if bad MAF?
I have 590-600 RPM on 1sz-fe, but normal are 640-650?
did you take off the idle control valve from the TB to clean it?
Yes, cleaned everything from the first days - IACV, throttle body, PCV, vapor solenoid etc.
With a decrease in weather temperatures, the symptoms intensified.
when actively moving from a stop sign, traffic lights, the engine almost does not respond to pressing the gas pedal for 1-2 seconds, then we have few jerks, and after that the revs pick up sharply and after 1600-1800 the engine is going, as it should be.
spent another couple of hours looking for information on various forums.
the main reasons for someone who solved a similar problem - there was clogging of the fuel system and MAF,
MAF which gave data, but not those that correspond to reality.
for example, 3.4 g/s enters the engine, but the MAF shows 2.5 g/s to the ECU.
if  I can imagine something similar with the MAF,
then with the fuel system... it is not very clear - if the fuel filter is clogged, or the fuel pump is weak - why does the car drive quite dynamically at 2000-7000 RPMs?
oh, and I forgot to add - if  I press the gas very smoothly, then nothing strange is noticeable at all,
the engine picks up RPMs normally, and the car speeds up without any problems, zero hesitations.
undo the fuel cap and see if it still does it
still does(
Replace the TPS
  • Confused 1
38 minutes ago, flash22 said:
Replace the TPS
But when engine is cold, there is no symptoms, only on warm.
Whole throttle body was changed (with TPS and IACV).
During the replacement, the Battery was disconnected (ECU reset).
There were no symptoms for the first 10-15 km.Then everything went back. So - zero changes. When the gas pressed sharply - the engine chokes and wants to stall (600->1500 RPM), but after 1-2 seconds - revs up sharply and everything work normally.
that is classic OCV getting stuck it may be fine when cold but out of spec when hot
I took it out and checked it - it clicked when applying 12 volts, and it was also perfectly clean (just in engine oil), it also runs freely and without obstacles during a manual-mechanical (screwdriver) test. + It has normal resistance in Omh
ECU (from 1.3 (but the "same" 89661-0D211)) was replaced (+ immo-eeprom resoldering).
35km was done today - no hesitations, the car is unrecognizable, out of habit - I even squealed with the tyres at traffic lights a couple of times))
let's watch further..
+50 km, zero hesitations. Сar starts instantly, and I also noticed an increase in power at all revs, now I have a feeling that I am not driving on 1.0L, but at least 1.3 :)). +the average fuel consumption in the city (according to the the dashboard) - decreased from 8.0L to 7.2L
+200km, runs great. So it was ECU (incorrect software probably). it is surprising that 2 previous owners for 160,000 km were fine with all this.
The repair, together with the purchase of unnecessary things, cost about $50. Thanx to everybody for the help.
