Hi everyone from Harrogate
John D Kennett
😀 I now own a Proace 2018 model with 62,000 miles on the clock
unable to get heat on drivers side with either A/C on or off, it’s made me rather upset as I had that a few years back on a Saab96 estate
Hello and welcome, John.
Hello John - welcome to Toyota Owners Club.
Hi John, welcome lots of good advice when you need it and always welcome when you give it.😀
It sounds like an issue with the heating system on the driver’s side. There are a few possible causes. If your car has dual-zone climate control, a faulty blend door actuator might be stuck, blocking warm air. A partial blockage in the heater matrix could cause uneven heating. A coolant system flush might help.Low coolant can affect heating, so check the reservoir and top it up if needed.Trapped air in the cooling system might block the flow of hot coolant. Bleeding the system might fix this. A faulty HVAC control panel or temperature sensor could also be the problem.If your Proace is under Toyota warranty book it in to be looked at.👍
Hi John,
Welcome to our forum
