Hi everyone, thank you for the add, first post.
I have searched for this and not found any specific information.
Does anyone know if the JDM Fielder NRE161G reverse camera has a 4pin connector at the stereo end? and whether it runs on 6V or 12V?
Wanting to connect OEM reverse camera to my aftermarket android auto head unit, have a rough idea on how to do it and just need to buy an adapter to connect up...but dont want to buy the wrong one. I think most likely It'll be a 4pin connector, but some Toyota's have 24pin connectors etc. Unfortunately I have no OEM headunit to plug/unplug connectors until I isolate the reverse camera one.
Hi Chris,@flash22 is the best person to help you with this.👍
Thanks @Bper, will keep an eye out on here for any sage advice
Update - have managed to get the OEM camera working. It was fairly straightforward in the end. Can confirm camera runs on 6V and it is a 4-pin connector.
I had to connect up a little 12V-6V reducer that I bought off AliExpress for $5NZD. Hardest thing was finding this on AliExpress, so if you search, "Reverse Backup Camera 4-Pin For Toyota Connector" it should come up.
Wiring in fairly straightforward. Connect up the 4-pin to factory side and RCA to headunit RCA. Then splice red wire to 12V acc source and black wire to ground (used gray and brown wires from main 10-pin radio harness for this, but you would need to just go off whatever wire colour is specific for your vehicle, see https://pinoutguide.com/Car-Stereo-Toyota-Lexus/ ).
Lastly, in order to make the camera show on the screen when you put car in reverse you need to have a reverse signal going to the head-unit. To find this is just trial and error with a multi-meter. Took a couple minutes flicking in and out of reverse while checking voltage on wires for the unused connectors sitting behind the head unit. It ended up being a purple wire on a 5 pin connector, which needs to be connected to the headunits wire labelled "back" or "reverse".
WhatsAppImage2024-10-01at11_00_51.thumb.jpeg.7a1183f5648de4408eabf90fade04fb4.jpegWhatsAppImage2024-10-01at10_50_42.thumb.jpeg.b1d61807ccbc26a1d881b4c71d580192.jpegWhatsAppImage2024-10-01at10_50.41(1).thumb.jpeg.1c1e73aa082baa85593d2199c69396d7.jpeg
Hope this is helpful for someone in the future!
